Zum Hauptinhalt wechseln
Einleitung
Introduction
This guide shows how to remove and replace the antenna of the Nokia 2630b after full disassembly of the phone.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Press the release buttons located on either side of the battery cover Pull the battery cover away from the phone
    • Press the release buttons located on either side of the battery cover
    • Pull the battery cover away from the phone
  2. Gently pull the battery out of the phone with your fingers Gently pull the battery out of the phone with your fingers
    • Gently pull the battery out of the phone with your fingers
  3. Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Separate the front case from the back case using the iPod opener NOTE: The keypad is a loose piece and may fall out NOTE: The keypad is a loose piece and may fall out
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Remove screws using the same T5 screw bit to release the computer chip from the case
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Carefully lift the black frame off the screen with your fingers
    • Carefully lift the black frame off the screen with your fingers
  7. Carefully remove the computer chip and screen out of the black case with your fingers
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  9. The screen is attached to the motherboard by an orange ribbon Carefully detach the ribbon from the motherboard using your fingers
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  10. Reattach new screen by connecting the orange ribbon to the computer chip
    • Reattach new screen by connecting the orange ribbon to the computer chip
  11. Place computer chip and screen back into black case Place computer chip and screen back into black case
    • Place computer chip and screen back into black case
  12. Place black frame back over screen
    • Place black frame back over screen
  13. Carefully place keypad back in place Carefully place keypad back in place
    • Carefully place keypad back in place
  14. Snap the front case back in place with the bottom case with your fingers Snap the front case back in place with the bottom case with your fingers
    • Snap the front case back in place with the bottom case with your fingers
  15. Reassemble screws with microscrewdriver
    • Reassemble screws with microscrewdriver
  16. Slide battery back into place
    • Slide battery back into place
  17. Snap battery cover back into place
    • Snap battery cover back into place
  18. Locate the four screws that secure the back case to the rest of the phone. Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
    • Locate the four screws that secure the back case to the rest of the phone.
    • Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
  19. DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone. Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components. Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
    • DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone.
    • Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
  20. The antenna is the "L" shaped device located on the top of the phone in between the back case and the board.
    • The antenna is the "L" shaped device located on the top of the phone in between the back case and the board.
    • You should be able to remove the antenna with minimal effort.
    • To put in a new antenna, place it in the same location as the old one. There is no need to connect to any hardware on the phone.
  21. To reassemble the device, follow the instructions in reverse order.
    • To reassemble the device, follow the instructions in reverse order.
    • When reinstalling the keyboard, make sure it is in the correct position before screwing the case back together.
    • When reinstalling the battery, make sure the contacts of the battery connect to the contacts on the phone.
    • The red square in the photo indicates the position of the brass contacts of the battery.
    • The photo displays the correct orientation of the battery.
Ziellinie
Eric
51 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 9-61, Walters Spring 2011 Mitglied von Cal Poly, Team 9-61, Walters Spring 2011
CPSU-WALTERS-S11S9G61
5 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 2,891
