Einleitung
Introduction
In this guide, we show how to unscrew and remove the back case of the Nokia 2630b. This enables access to the motherboard, antenna, and LCD screen of the phone.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Press the release buttons located on either side of the battery cover
Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
NOTE: Keep the screws in a safe place while you continue working.
Remove screws using the same T5 screw bit to release the computer chip from the case
Carefully remove the computer chip and screen out of the black case with your fingers
The screen is attached to the motherboard by an orange ribbon
Carefully detach the ribbon from the motherboard using your fingers
Locate the four screws that secure the back case to the rest of the phone.
Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
