Was du brauchst
Remove the Back cover by Pressing the release buttons located on either side of the battery cover
Now Remove The Battery and Simcard from the slots
Remove the two screws on either side of the back side using the microscrewdriver using the T5 bit
Now Remove the Front key panel from the Main Board Carefully using the Plastic Opening Tools
Now Remove the four screws in the front side of the main board
Now push the Board from the Battery slot side and carefully By using the Plastic Opening Tools Separate the board from the back case or rear case
Now Gently Separate the lock at the right side to remove the outer cover of the Main Board
!!!! Be Cautious that the key panel is attached at the other end
Remove the Chip which is attached to the main board
Now we can separate the display from the main board and we can replace it with the new display.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
