Zum Hauptinhalt wechseln
Nokia 3.1 Battery Replacement
Was du brauchst
  1. Nokia 3.1 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Battery Replacement, Open the back cover: Schritt 2, Bild 1 von 3 Nokia 3.1 Battery Replacement, Open the back cover: Schritt 2, Bild 2 von 3 Nokia 3.1 Battery Replacement, Open the back cover: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Battery Replacement, Remove logic board cover: Schritt 3, Bild 1 von 2 Nokia 3.1 Battery Replacement, Remove logic board cover: Schritt 3, Bild 2 von 2
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Battery Replacement, Remove battery adhesive strips: Schritt 4, Bild 1 von 2 Nokia 3.1 Battery Replacement, Remove battery adhesive strips: Schritt 4, Bild 2 von 2
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
Abschluss
To reassemble your device, follow these instructions in reverse order. Also don’t forget some double-faced adhesive tape to fixate the new battery.
9 weitere Personen haben diese Anleitung absolviert.
Baschtl
1.688 Reputation
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
Merci beaucoup
GEORGES Sylvestre - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 48
Insgesamt: 8,347
