Einleitung
To change or clean the logic board the phone must be dissembled. The tools required will be a T-6 screw driver.
Was du brauchst
Flip the Nokia 3300B over with the back-side facing towards you.
Gently press the button on the back of the battery cover to release the cover and slide up.
Gently push the blue tabs on the top of the phone out of their slots.
With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
Pull up on the front case containing the screen to separate it from the rest of the phone.
Gently lift the main board out of the back case.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
