Zum Hauptinhalt wechseln
Nokia 3300B Screen Replacement
Was du brauchst
  1. Nokia 3300B Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia 3300B Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Screen Replacement: Schritt 2, Bild 1 von 2 Nokia 3300B Screen Replacement: Schritt 2, Bild 2 von 2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Screen Replacement, Screen: Schritt 3, Bild 1 von 3 Nokia 3300B Screen Replacement, Screen: Schritt 3, Bild 2 von 3 Nokia 3300B Screen Replacement, Screen: Schritt 3, Bild 3 von 3
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Screen Replacement: Schritt 4, Bild 1 von 1
    • With the screen still facing you, remove the blue faceplate.
  5. Nokia 3300B Screen Replacement: Schritt 5, Bild 1 von 2 Nokia 3300B Screen Replacement: Schritt 5, Bild 2 von 2
    • Grab the sides of the keypad and lift it up vertically.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides, so the button's pin don't snap.
  6. Nokia 3300B Screen Replacement: Schritt 6, Bild 1 von 3 Nokia 3300B Screen Replacement: Schritt 6, Bild 2 von 3 Nokia 3300B Screen Replacement: Schritt 6, Bild 3 von 3
    • Using the Torx T6 bit of a Phillips precision screwdriver, remove the six screws on the phone's inner protective case, as seen in the picture.
    • NOTE: Be sure to save these screws so the phone can be reassembled later.
  7. Nokia 3300B Screen Replacement: Schritt 7, Bild 1 von 2 Nokia 3300B Screen Replacement: Schritt 7, Bild 2 von 2
    • Holding the phone with the screen facing you, remove the top half of the phone from the circuit board.
  8. Nokia 3300B Screen Replacement: Schritt 8, Bild 1 von 3 Nokia 3300B Screen Replacement: Schritt 8, Bild 2 von 3 Nokia 3300B Screen Replacement: Schritt 8, Bild 3 von 3
    • Hold the top half of the phone with the screen facing you.
    • Using a pair of tweezers, release the tabs holding the two distinct cases together.
    • The tabs are very fragile. Be gentle when releasing the tabs.
  9. Nokia 3300B Screen Replacement: Schritt 9, Bild 1 von 1
    • Be sure to remove both casings so that the screen is facing down. This will ensure that the screen does not fall out of its case.
    • NOTE: The screen's part identification sticker is on the top back side of the screen. The screen will need to be replaced with the same orientation.
  10. Nokia 3300B Screen Replacement: Schritt 10, Bild 1 von 1
    • Tilt the casing back and the screen should fall out smoothly.
    • Replace the old screen with the new screen.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris Colwell
107 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 18-65, Johann Spring 2010 Mitglied von Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 3,098
