Zum Hauptinhalt wechseln
Einleitung
Changing the Battery is easy -- no tools required.
  1. Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  4. Lift the battery out of the phone. Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Travis Malmgren
69 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-39, Regan Winter 2010 Mitglied von Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 2,128
