Zum Hauptinhalt wechseln
Nokia 5130 XpressMusic Logic Board / Casing Replacement
Was du brauchst
  1. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Sliding off the rear panel: Schritt 1, Bild 1 von 1
    • Slide the rear panel in the indicated direction to unlock it.
  2. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: Schritt 2, Bild 1 von 2 Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: Schritt 2, Bild 2 von 2
    • After unlocking it, the rear panel can now be lifted up.
  3. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Rear screws: Schritt 3, Bild 1 von 1
    • Remove the two T6 screws near the camera
  4. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Unclip the bezel: Schritt 4, Bild 1 von 1
    • Unclip the several clips holding the front bezel in place
    • Be sure not to break off or damage the clips, otherwise the front bezel might no longer stay in place!
  5. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Keypad: Schritt 5, Bild 1 von 1
    • Push in the pins holding in the keypad
  6. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the keypad: Schritt 6, Bild 1 von 1
    • The keypad can now be removed.
  7. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the remaining parts: Schritt 7, Bild 1 von 1
    • Lift up the logic board / display and remove it from the case.
Abschluss
iSzymon
573 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 262
