Was du brauchst
Remove the battery by pushing the button and sliding the battery out a bit then pulling it out
Find the tab at the top of the phone and press down with your fingernail or the flat end of a spudger
The top of the cover should pop out and then pull the top part out and the whole thing should come off
Remove these screws
4 T6 Torx Screws
Lift up the white cover
Remove these screws
2 T6 Torx screws
Lift up the screen and number pad assembly
Remove the blue seperator and put it on the new screen
