Einleitung
Follow this guide to replace your Nokia 6 microphone.
In this guide, you do not have to take apart the front and rear facing cameras from the motherboard. Simply removing the motherboard will expose the parts needed for the next steps.
Was du brauchst
Insert the SIM card ejection tool into the hole on the left side of the phone.
Remove the SIM card and microSD card.
Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
To use the heat gun, plug it into an outlet.
Take a Jimmy and slide it under the glass after the adhesive has been softened.
Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
Use a spudger to disconnect the screen ribbon connector and free the display assembly.
Carefully remove the screen from the device.
Detach the cable with the black nylon spudger.
Detach the home button and remove it from the device.
Remove 18 screws.
There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
Decouple the midframe with the spudger and remove the midframe from the device.
Detach the two cables with the spudger.
Detach the cable with a pair of tweezers.
Remove six screws.
Two of these screws are 1.0 mm x 1.4 mm and need to be removed by a Phillips #000 screwdriver.
The remaining four screws are 1.2 mm x 2.2 mm and are removed by a Phillips #00 screwdriver.
Remove three screws.
Two of these are 1 mm x 1.4 mm and can be removed by a Phillips #000.
One of the screws is 1.2 mm x 2.2 mm and can be removed by a Phillips #00.
Remove the microUSB port and the microphone by lifting the unit with a spudger.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Thanks. I used this guide to help me replace the thermal paste TIM on my LG V20 H990DS… It did make the phone more stable, but didn’t fix image ghosting… Oh well. Thanks again! 8 ball pool
