Zum Hauptinhalt wechseln
Nokia 6030 Microphone Replacement
Was du brauchst
  1. Nokia 6030 Microphone Replacement, Battery: Schritt 1, Bild 1 von 3 Nokia 6030 Microphone Replacement, Battery: Schritt 1, Bild 2 von 3 Nokia 6030 Microphone Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Nokia 6030 Microphone Replacement: Schritt 2, Bild 1 von 3 Nokia 6030 Microphone Replacement: Schritt 2, Bild 2 von 3 Nokia 6030 Microphone Replacement: Schritt 2, Bild 3 von 3
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Nokia 6030 Microphone Replacement, SIM Card: Schritt 3, Bild 1 von 3 Nokia 6030 Microphone Replacement, SIM Card: Schritt 3, Bild 2 von 3 Nokia 6030 Microphone Replacement, SIM Card: Schritt 3, Bild 3 von 3
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Nokia 6030 Microphone Replacement: Schritt 4, Bild 1 von 1
    • Use your finger to close the metal cage.
  5. Nokia 6030 Microphone Replacement, Front Cover: Schritt 5, Bild 1 von 3 Nokia 6030 Microphone Replacement, Front Cover: Schritt 5, Bild 2 von 3 Nokia 6030 Microphone Replacement, Front Cover: Schritt 5, Bild 3 von 3
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
  6. Nokia 6030 Microphone Replacement: Schritt 6, Bild 1 von 2 Nokia 6030 Microphone Replacement: Schritt 6, Bild 2 von 2
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Nokia 6030 Microphone Replacement: Schritt 7, Bild 1 von 3 Nokia 6030 Microphone Replacement: Schritt 7, Bild 2 von 3 Nokia 6030 Microphone Replacement: Schritt 7, Bild 3 von 3
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
  8. Nokia 6030 Microphone Replacement, Microphone: Schritt 8, Bild 1 von 3 Nokia 6030 Microphone Replacement, Microphone: Schritt 8, Bild 2 von 3 Nokia 6030 Microphone Replacement, Microphone: Schritt 8, Bild 3 von 3
    • Remove the six screws with a T-6 Torx screwdriver.
  9. Nokia 6030 Microphone Replacement: Schritt 9, Bild 1 von 3 Nokia 6030 Microphone Replacement: Schritt 9, Bild 2 von 3 Nokia 6030 Microphone Replacement: Schritt 9, Bild 3 von 3
    • Lift the logic board and screen from the top.
    • Be careful of loose parts.
  10. Nokia 6030 Microphone Replacement: Schritt 10, Bild 1 von 3 Nokia 6030 Microphone Replacement: Schritt 10, Bild 2 von 3 Nokia 6030 Microphone Replacement: Schritt 10, Bild 3 von 3
    • Use tweezers to aid in the removal of the microphone.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 23-63, Johann Spring 2010 Mitglied von Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 14
Insgesamt: 3,089
