Zum Hauptinhalt wechseln
Einleitung
Guide to replace the phones speaker.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
    • Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Use your fingernail and gently pull the the bottom of the battery up. Lift out battery and remove. Lift out battery and remove.
    • Use your fingernail and gently pull the the bottom of the battery up.
    • Lift out battery and remove.
  3. Use your fingernail to lift the metal cage up. Remove SIM card. Remove SIM card.
    • Use your fingernail to lift the metal cage up.
    • Remove SIM card.
  4. Close the metal cage.
    • Close the metal cage.
  5. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
    • Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
  6. After removing the top cover, turn the phone over so the screen is facing upwards. After removing the top cover, turn the phone over so the screen is facing upwards.
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows.
    • Lift the front off the phone by pulling above the arrows.
  8. Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver.
    • Remove the six screws with a T-6 Torx screwdriver.
  9. Lift the logic board and screen from the top. Be careful of loose parts. Be careful of loose parts.
    • Lift the logic board and screen from the top.
    • Be careful of loose parts.
  10. Lift the speaker out of the back housing of the phone. The speaker should come out with little effort. The speaker should come out with little effort.
    • Lift the speaker out of the back housing of the phone.
    • The speaker should come out with little effort.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Spencer Woodworth
310 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 23-63, Johann Spring 2010 Mitglied von Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Mitglieder
17 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 3,766
