Einleitung
Gather tools needed. Have a small tray or container on hand to hold screws and cell phone parts as you disassemble and reassemble the Nokia 6061.
Was du brauchst
Gather the necessary tools:
T6 Torx screwdriver
Plastic opening tool
Small flathead screwdriver
This guide will show you how to replace the LCD—after it's been dropped one too many times.
In diesem Schritt verwendetes Werkzeug:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using a 2.0 flathead screwdriver, pry open and remove the black, plastic strip (beneath the screen) to reveal the 2 screws holding the screen in place.
Once the screws are removed, flip the phone shut.
Insert the plastic opening tool at the position indicated and pry along the seam between the front cover and display.
Continue prying along the perimeter of the front cover until it is free from the phone.
Use a plastic opening tool to pry the LCD circuit board up and out of the phone.
Use a plastic opening tool to gently pry the LCD ribbon cable connector up out its socket on the LCD circuit board.
The other two photos show the male and female sides of the small green connector. Make sure they snap together tightly when the new display is attached.
To reassemble your phone, reattach the display to the phone by reconnecting the display ribbon cable. Place the screen assembly back into the front case of the phone.
With the cover reattached, flip the phone into the open position and replace the screws removed in step 3. The screw-holes are indicated in the photo.
Replace the black, plastic strip by applying pressure until the strip audibly clicks into place.
