Zum Hauptinhalt wechseln
Nokia 6086 Logic Board Replacement
Was du brauchst
  1. Nokia 6086 Logic Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Logic Board Replacement: Schritt 2, Bild 1 von 3 Nokia 6086 Logic Board Replacement: Schritt 2, Bild 2 von 3 Nokia 6086 Logic Board Replacement: Schritt 2, Bild 3 von 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Logic Board Replacement: Schritt 3, Bild 1 von 3 Nokia 6086 Logic Board Replacement: Schritt 3, Bild 2 von 3 Nokia 6086 Logic Board Replacement: Schritt 3, Bild 3 von 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Nokia 6086 Logic Board Replacement, Upper Back Cover: Schritt 4, Bild 1 von 1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Nokia 6086 Logic Board Replacement: Schritt 5, Bild 1 von 2 Nokia 6086 Logic Board Replacement: Schritt 5, Bild 2 von 2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Nokia 6086 Logic Board Replacement: Schritt 6, Bild 1 von 2 Nokia 6086 Logic Board Replacement: Schritt 6, Bild 2 von 2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Nokia 6086 Logic Board Replacement: Schritt 7, Bild 1 von 3 Nokia 6086 Logic Board Replacement: Schritt 7, Bild 2 von 3 Nokia 6086 Logic Board Replacement: Schritt 7, Bild 3 von 3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
  8. Nokia 6086 Logic Board Replacement, Base of The Phone: Schritt 8, Bild 1 von 2 Nokia 6086 Logic Board Replacement, Base of The Phone: Schritt 8, Bild 2 von 2
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
  9. Nokia 6086 Logic Board Replacement: Schritt 9, Bild 1 von 2 Nokia 6086 Logic Board Replacement: Schritt 9, Bild 2 von 2
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
  10. Nokia 6086 Logic Board Replacement: Schritt 10, Bild 1 von 2 Nokia 6086 Logic Board Replacement: Schritt 10, Bild 2 von 2
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
  11. Nokia 6086 Logic Board Replacement, Logic Board: Schritt 11, Bild 1 von 2 Nokia 6086 Logic Board Replacement, Logic Board: Schritt 11, Bild 2 von 2
    • Remove the logic board from the back cover of the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrea
70 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 26-30, Regan Spring 2010 Mitglied von Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,645
