Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to remove and repair the inside display screen.
Ersatzteile
Keine Ersatzteile angegeben.
  1. This step does not require much force. Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen. Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen.
    • This step does not require much force.
    • Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen.
  2. Have a container ready to keep track of small parts. Use the t6 screwdriver to remove the two visible screws that are immediately below the screen.
    • Have a container ready to keep track of small parts.
    • Use the t6 screwdriver to remove the two visible screws that are immediately below the screen.
  3. Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches. Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches.
    • Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches.
  4. Pull out the circuit board, which will remove it completely from the case Pull out the circuit board, which will remove it completely from the case
    • Pull out the circuit board, which will remove it completely from the case
  5. If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen. If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen. If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen.
    • If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen.
  6. Be gentle when pulling off the display screen. If pulled too hard, the orange connecting ribbon will rip. Lift off the display screen and disconnect it from the circuit board.
    • Be gentle when pulling off the display screen. If pulled too hard, the orange connecting ribbon will rip.
    • Lift off the display screen and disconnect it from the circuit board.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
Alex Graebe
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 23-78, Johann Spring 2010 Mitglied von Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 4,017
