Einleitung
This guide requires that the front plate and keypad already be removed. You will have to remove 6 screws and separate the circuit board from the rest of the phone.
Was du brauchst
Pull up on both of the clips near the bottom of the phone as shown.
Lift off the front plate.
Separate the keypad from the phone and place aside.
Wipe off any excess dust from where the keypad was attached to the phone.
Remove the 6 - 7.9 mm screws highlighted by the markers using the T-6 head on the screwdriver.
To reattach the circuit board, line up the connector at the top of the board with the back of the LCD Screen attachment. Place the two boards together, and screw in the 6 screws.
