Ersatzteile
Kein Ersatzteil erforderlich.
  1. Press and hold the battery release button and slide the battery away from the Nokia logo Press and hold the battery release button and slide the battery away from the Nokia logo
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Slide the SIM card lock away from the SIM card. The SIM card pops out. Remove the SIM card. The SIM card pops out. Remove the SIM card.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Unscrew and remove the four T6 Torx screws.
    • Unscrew and remove the four T6 Torx screws.
  5. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  6. Use the plastic opening tool to separate the top part of the backplate. The plastic clips at the top require slightly more force to separate. The plastic clips at the top require slightly more force to separate.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Mustafa
139 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-41, Forte Fall 2010 Mitglied von Cal Poly, Team 14-41, Forte Fall 2010
CPSU-FORTE-F10S14G41
5 Mitglieder
16 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 3,669
