Was du brauchst
Press and hold the battery release button and slide the battery away from the Nokia logo
Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
Gently pop out the golden spring in the middle of the speaker. It should come out with little force.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
