Einleitung
Use this guide to replace the display screen of the Nokia 6350-1b cellphone.
Was du brauchst
Using a plastic pry, get between the plastic frame and the rest of the phone.
Move the plastic pry along the frame unlocking all of the locks that keep the frame in place.
Remove the plastic frame.
Be careful not to pry too hard, doing so could crack the plastic frame.
Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
Using a pry, get between the screen cover and the rest of the phone.
Move along this layer unlocking the various locks that keep it in place.
Carefully remove the screen cover to reveal the logic board.
Keep track of the four small screws. They will be needed to put the phone back together.
Disconnect the flex cable from the logic board.
Disconnect the LCD display screen.
Remove the LCD display screen from the rest of the device.
Connect the new LCD display screen to the phone.
Reconnect the Logic Board to the flex cable.
Place the cover back on the device so that it is in the correct position to be reinstalled.
Press gently on the cover so that it snaps back into place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
