Zum Hauptinhalt wechseln
Nokia 6560 Logic Board Replacement
Was du brauchst
  1. Nokia 6560 Logic Board  Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia 6560 Logic Board  Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 Logic Board  Replacement: Schritt 2, Bild 1 von 2 Nokia 6560 Logic Board  Replacement: Schritt 2, Bild 2 von 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 Logic Board  Replacement, Keypad: Schritt 3, Bild 1 von 2 Nokia 6560 Logic Board  Replacement, Keypad: Schritt 3, Bild 2 von 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 Logic Board  Replacement: Schritt 4, Bild 1 von 2 Nokia 6560 Logic Board  Replacement: Schritt 4, Bild 2 von 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
  5. Nokia 6560 Logic Board  Replacement, Logic Board : Schritt 5, Bild 1 von 1
    • Remove six Torx 6 screws with the screwdriver.
  6. Nokia 6560 Logic Board  Replacement: Schritt 6, Bild 1 von 1
    • Remove the frame that holds the keyboard and the display.
  7. Nokia 6560 Logic Board  Replacement: Schritt 7, Bild 1 von 1
    • Lift the logic board of out the rear case of the phone.
  8. Nokia 6560 Logic Board  Replacement: Schritt 8, Bild 1 von 2 Nokia 6560 Logic Board  Replacement: Schritt 8, Bild 2 von 2
    • This is the logic board of your cell phone.
    • Make sure that you get the right logic board to replace your old one by comparing the serial numbers on it.
Abschluss
Tim Bergmann
35 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 3-17, Maness Winter 2010 Mitglied von Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 2,165
