Zum Hauptinhalt wechseln
Nokia 6590i Vibrator Replacement
Was du brauchst
  1. Nokia 6590i Vibrator Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia 6590i Vibrator Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Vibrator Replacement: Schritt 2, Bild 1 von 1
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Vibrator Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: Schritt 3, Bild 1 von 1
    • Grip the front cover from the bottom.
  4. Nokia 6590i Vibrator Replacement: Schritt 4, Bild 1 von 1
    • Lift the front cover off.
  5. Nokia 6590i Vibrator Replacement: Schritt 5, Bild 1 von 1
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Vibrator Replacement: Schritt 6, Bild 1 von 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Vibrator Replacement: Schritt 7, Bild 1 von 1
    • Remove assembly from phone
  8. Nokia 6590i Vibrator Replacement, Logic Board: Schritt 8, Bild 1 von 1
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Vibrator Replacement: Schritt 9, Bild 1 von 1
    • Lift the logic board out of the phone.
  10. Nokia 6590i Vibrator Replacement, Battery Charger Connector: Schritt 10, Bild 1 von 1
    • Locate battery charger connector
  11. Nokia 6590i Vibrator Replacement: Schritt 11, Bild 1 von 1
    • Grasp top and bottom of battery charger connector on the left side
  12. Nokia 6590i Vibrator Replacement: Schritt 12, Bild 1 von 1
    • Lift out the battery charger connector
  13. Nokia 6590i Vibrator Replacement, Vibrator: Schritt 13, Bild 1 von 1
    • Grasp vibrator which protrudes from the battery charger connector
  14. Nokia 6590i Vibrator Replacement: Schritt 14, Bild 1 von 1
    • Lift the vibrator out of the battery charger connector.
Abschluss
Cal Poly, Team 22-3, Maness Fall 2010 Mitglied von Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,112
