Zum Hauptinhalt wechseln
Nokia 8260 Antenna Replacement
Was du brauchst
  1. Nokia 8260 Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the cell phone.
  2. Nokia 8260 Antenna Replacement: Schritt 2, Bild 1 von 1
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Antenna Replacement: Schritt 3, Bild 1 von 1
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Antenna Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover.
  5. Nokia 8260 Antenna Replacement: Schritt 5, Bild 1 von 1
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Antenna Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Antenna Replacement, Antenna: Schritt 7, Bild 1 von 1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Antenna Replacement: Schritt 8, Bild 1 von 1
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Antenna Replacement: Schritt 9, Bild 1 von 1
    • Remove the antenna door.
  10. Nokia 8260 Antenna Replacement: Schritt 10, Bild 1 von 1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Aaron Jen
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 27-94, Amido Spring 2010 Mitglied von Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,220
