Zum Hauptinhalt wechseln
Nokia 8265 Display Screen/Keyboard Replacement
Was du brauchst
  1. Nokia 8265 Display Screen/Keyboard Replacement, Display Screen/Keyboard: Schritt 1, Bild 1 von 1
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Display Screen/Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Display Screen/Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Display Screen/Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Display Screen/Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
  6. Nokia 8265 Display Screen/Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Now you have successfully removed the display screen and keyboard.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jack
1 Reputation
4 Anleitungen geschrieben
SUNY Cortland, Team 1-1, Getto Spring 2012 Mitglied von SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 14
Insgesamt: 920
