Zum Hauptinhalt wechseln
Nokia 8390 Motherboard Replacement
Was du brauchst
  1. Nokia 8390 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Motherboard Replacement: Schritt 2, Bild 1 von 3 Nokia 8390 Motherboard Replacement: Schritt 2, Bild 2 von 3 Nokia 8390 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Motherboard Replacement, Outer Case: Schritt 3, Bild 1 von 3 Nokia 8390 Motherboard Replacement, Outer Case: Schritt 3, Bild 2 von 3 Nokia 8390 Motherboard Replacement, Outer Case: Schritt 3, Bild 3 von 3
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Motherboard Replacement, Keypad: Schritt 4, Bild 1 von 3 Nokia 8390 Motherboard Replacement, Keypad: Schritt 4, Bild 2 von 3 Nokia 8390 Motherboard Replacement, Keypad: Schritt 4, Bild 3 von 3
    • Lightly peel the keypad off of the phone.
  5. Nokia 8390 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 Nokia 8390 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 Nokia 8390 Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  6. Nokia 8390 Motherboard Replacement: Schritt 6, Bild 1 von 3 Nokia 8390 Motherboard Replacement: Schritt 6, Bild 2 von 3 Nokia 8390 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  7. Nokia 8390 Motherboard Replacement: Schritt 7, Bild 1 von 3 Nokia 8390 Motherboard Replacement: Schritt 7, Bild 2 von 3 Nokia 8390 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  8. Nokia 8390 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
Abschluss
Clinton
57 Reputation
7 Anleitungen geschrieben
Clemson, Team 14-5, Benson Fall 2012 Mitglied von Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 481
