Einleitung
This guide shows you how to remove or install the SIM card in case of needed replacement.
Was du brauchst
Depress the button with your finger.
While the button is depressed, slide the back cover off of the phone.
Place the phone so that the battery is face up.
Insert a screwdriver or spudger into the crevice above the battery.
Place the spudger under the plastic cover and lightly lift.
Insert the SIM Card under the plastic cover and close.
