Zum Hauptinhalt wechseln
Nokia Asha 201 Audio Jack Replacement
Was du brauchst
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: Schritt 1, Bild 1 von 1
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: Schritt 4, Bild 1 von 1
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: Schritt 5, Bild 1 von 1
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: Schritt 7, Bild 1 von 1
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: Schritt 8, Bild 1 von 1
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
Abschluss
Betsy Walker
157 Reputation
1 Anleitung geschrieben
USF Tampa, Team S1-G3, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 169
