Einleitung
Use this guide to replace a damaged or broken front case on your Nokia Asha 201.
The front case protects all the key components and electronics inside the phone. Removing the front case is easy and it is the first step in replacing almost any part of the phone.
Before getting started make sure to power off your phone that you have a Nokia Asha 201 front case to replace the old one with.
Was du brauchst
Take the back cover of the device off by sliding the cover up and removing it.
