Zum Hauptinhalt wechseln
Nokia Asha 201 Screen Replacement
Was du brauchst
  1. Nokia Asha 201 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Remove back cover of device by pressing firmly and sliding the cover off.
  2. Nokia Asha 201 Screen Replacement: Schritt 2, Bild 1 von 1
    • Using your finger, lift up on battery to remove from the device.
  3. Nokia Asha 201 Screen Replacement: Schritt 3, Bild 1 von 1
    • Using a screwdriver, remove the two screws from the back case.
  4. Nokia Asha 201 Screen Replacement: Schritt 4, Bild 1 von 1
    • Pry off the front case using a iFixit opening tool.
  5. Nokia Asha 201 Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the Keyboard with your hands.
  6. Nokia Asha 201 Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the four screws pictured here.
  7. Nokia Asha 201 Screen Replacement: Schritt 7, Bild 1 von 1
    • Using the iFixit opening tool, separate the screen from motherboard.
    • Unplug your old screen from your phone, unpack your new one and gently plug in the new screen. Make sure you plug in the screen just like the old one was placed in the phone.
  8. Nokia Asha 201 Screen Replacement: Schritt 9, Bild 1 von 1
    • After plugging in the new screen put back the screen onto the motherboard.
  9. Nokia Asha 201 Screen Replacement: Schritt 10, Bild 1 von 1
    • Use a philips #00 screwdriver to put back the four 3.5 mm screws trays pictured here.
  10. Nokia Asha 201 Screen Replacement: Schritt 11, Bild 1 von 1
    • Using your fingers place the keyboard back like in the picture.
  11. Nokia Asha 201 Screen Replacement: Schritt 12, Bild 1 von 1
    • Using your fingers and the Phillips opening tool reposition and adjust the front case onto the phone.
  12. Nokia Asha 201 Screen Replacement: Schritt 13, Bild 1 von 1
    • Using the Phillips #0 screwdriver, screw back in the two screws to the back case.
  13. Nokia Asha 201 Screen Replacement: Schritt 14, Bild 1 von 1
    • Using your fingers put back the battery in the back of the phone properly.
  14. Nokia Asha 201 Screen Replacement: Schritt 15, Bild 1 von 1
    • Slide back in the phone cover to the back of the device.
Abschluss
Replacing Nokia Asha 201 screen takes several steps. These steps should be followed precisely to have the screen replaced without complications. Each step should be done before start doing the next step. After you’re done following these steps, you should start reassembling the device. To reassemble the device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S1-G3, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 534
