Zum Hauptinhalt wechseln
Nokia E61i Motherboard Replacement
Was du brauchst
  1. Nokia E61i Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia E61i Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Motherboard Replacement, Front Cover: Schritt 4, Bild 1 von 2 Nokia E61i Motherboard Replacement, Front Cover: Schritt 4, Bild 2 von 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Motherboard Replacement, Display: Schritt 6, Bild 1 von 2 Nokia E61i Motherboard Replacement, Display: Schritt 6, Bild 2 von 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Motherboard Replacement: Schritt 7, Bild 1 von 2 Nokia E61i Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 3 Nokia E61i Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 3 Nokia E61i Motherboard Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Pull the green motherboard from the back casing.
Abschluss
Cal Poly, Team 9-63, Walters Spring 2011 Mitglied von Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 1,593
