Zum Hauptinhalt wechseln
Nokia E71x Camera Flash Replacement
Was du brauchst
  1. Nokia E71x Camera Flash Replacement, Motherboard: Schritt 1, Bild 1 von 2 Nokia E71x Camera Flash Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Remove battery
  2. Nokia E71x Camera Flash Replacement: Schritt 2, Bild 1 von 1
    • Using Torx number 4 unscrew the four 0.5mm screws.
  3. Nokia E71x Camera Flash Replacement: Schritt 3, Bild 1 von 1
    • Push in four clips to detach the body.
  4. Nokia E71x Camera Flash Replacement: Schritt 4, Bild 1 von 3 Nokia E71x Camera Flash Replacement: Schritt 4, Bild 2 von 3 Nokia E71x Camera Flash Replacement: Schritt 4, Bild 3 von 3
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
  5. Nokia E71x Camera Flash Replacement: Schritt 5, Bild 1 von 3 Nokia E71x Camera Flash Replacement: Schritt 5, Bild 2 von 3 Nokia E71x Camera Flash Replacement: Schritt 5, Bild 3 von 3
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
  6. Nokia E71x Camera Flash Replacement: Schritt 6, Bild 1 von 1
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
  7. Nokia E71x Camera Flash Replacement: Schritt 7, Bild 1 von 2 Nokia E71x Camera Flash Replacement: Schritt 7, Bild 2 von 2
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
  8. Nokia E71x Camera Flash Replacement: Schritt 8, Bild 1 von 1
    • Replace motherboard, ensure that replacement has the same serial number.
  9. Nokia E71x Camera Flash Replacement, Camera Flash: Schritt 9, Bild 1 von 1
    • Camera is located on back of camera body.
    • To remove flash turn body over and gently tap on the case. The flash should fall out.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Will Goldby
184 Reputation
4 Anleitungen geschrieben
Cuesta, Team 1-1, Zipperian Fall 2011 Mitglied von Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,070
