Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
You will need a Torx number 4 to complete this repair guide.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove battery Remove battery
    • Remove battery
  2. Using Torx number 4 unscrew the four  0.5mm screws.
    • Using Torx number 4 unscrew the four 0.5mm screws.
  3. Push in four clips to detach the body.
    • Push in four clips to detach the body.
  4. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  5. Separate the body into two pieces. Be careful not to damage the screen or body. Some force will be needed to separate the body. Be careful not to damage the screen or body. Some force will be needed to separate the body.
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
  6. Remove the bottom piece that is clipped on. Some force will need to be exerted to remove the clip. Some force will need to be exerted to remove the clip.
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
  7. Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
  8. Once screws are removed detach back of phone from the motherboard. This will require some force and maneuvering. Be careful not to break phone back or motherboard.
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
  9. Replace motherboard, ensure that replacement has the same serial number.
    • Replace motherboard, ensure that replacement has the same serial number.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Will Goldby
184 Reputation
4 Anleitungen geschrieben
Cuesta, Team 1-1, Zipperian Fall 2011 Mitglied von Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 2,839
