Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Start with the phone in the flipped open position.
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Flip the phone to the closed position and turn to the front screen. The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  3. With the front cover off, the screen and keypad should be loose.
    • With the front cover off, the screen and keypad should be loose.
  4. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  5. Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone. With the cable disconnected, the screen should be free for removal or replacement.
    • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
    • With the cable disconnected, the screen should be free for removal or replacement.
  6. After removing the front screen and front keypad, your device should look like this.
    • After removing the front screen and front keypad, your device should look like this.
  7. Using the T5 Screwdriver, remove the two screws shown. Using the T5 Screwdriver, remove the two screws shown. Using the T5 Screwdriver, remove the two screws shown.
    • Using the T5 Screwdriver, remove the two screws shown.
  8. Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
    • Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
  9. Gently, lift the board up to reveal the front screen. Gently, lift the board up to reveal the front screen.
    • Gently, lift the board up to reveal the front screen.
  10. Using the plastic opening tool, lift and remove the inside screen. Using the plastic opening tool, lift and remove the inside screen. Using the plastic opening tool, lift and remove the inside screen.
    • Using the plastic opening tool, lift and remove the inside screen.
Abschluss
In order to install a new screen, simply follow the steps in reverse order with the new screen.
4 weitere Nutzer haben diese Anleitung absolviert.
Cameron Weinberg
498 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 18-21, Garner Spring 2011 Mitglied von Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 20
Insgesamt: 4,725
