Zum Hauptinhalt wechseln
Nokia E90 QWERTY Keyboard Replacement
Was du brauchst
  1. Nokia E90 QWERTY Keyboard Replacement, Battery Cover and Battery: Schritt 1, Bild 1 von 1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 QWERTY Keyboard Replacement: Schritt 2, Bild 1 von 2 Nokia E90 QWERTY Keyboard Replacement: Schritt 2, Bild 2 von 2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 QWERTY Keyboard Replacement: Schritt 3, Bild 1 von 1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
  4. Nokia E90 QWERTY Keyboard Replacement, Back Cover: Schritt 4, Bild 1 von 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: Schritt 4, Bild 2 von 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: Schritt 4, Bild 3 von 3
    • Using a plastic opening tool, separate the back cover from the phone.
  5. Nokia E90 QWERTY Keyboard Replacement: Schritt 5, Bild 1 von 2 Nokia E90 QWERTY Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Continue along the edge with the plastic opening tool.
  6. Nokia E90 QWERTY Keyboard Replacement: Schritt 6, Bild 1 von 3 Nokia E90 QWERTY Keyboard Replacement: Schritt 6, Bild 2 von 3 Nokia E90 QWERTY Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Gently, remove the back cover.
  7. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: Schritt 7, Bild 1 von 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: Schritt 7, Bild 2 von 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: Schritt 7, Bild 3 von 3
    • Unscrew the indicated screws using the T5 screwdriver.
  8. Nokia E90 QWERTY Keyboard Replacement: Schritt 8, Bild 1 von 2 Nokia E90 QWERTY Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
    • Be careful not to break the plastic during this step; do your best not to force anything.
  9. Nokia E90 QWERTY Keyboard Replacement: Schritt 9, Bild 1 von 2 Nokia E90 QWERTY Keyboard Replacement: Schritt 9, Bild 2 von 2
    • The button board will be loose once the cover is removed.
    • Lift it up to reveal the sensor board.
  10. Nokia E90 QWERTY Keyboard Replacement: Schritt 10, Bild 1 von 2 Nokia E90 QWERTY Keyboard Replacement: Schritt 10, Bild 2 von 2
    • With the T5 Screwdriver, remove the marked screws.
  11. Nokia E90 QWERTY Keyboard Replacement: Schritt 11, Bild 1 von 2 Nokia E90 QWERTY Keyboard Replacement: Schritt 11, Bild 2 von 2
    • With the screws removed, the sensor board should be free to flip up.
  12. Nokia E90 QWERTY Keyboard Replacement: Schritt 12, Bild 1 von 2 Nokia E90 QWERTY Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the wire with the plastic opening tool.
  13. Nokia E90 QWERTY Keyboard Replacement: Schritt 13, Bild 1 von 3 Nokia E90 QWERTY Keyboard Replacement: Schritt 13, Bild 2 von 3 Nokia E90 QWERTY Keyboard Replacement: Schritt 13, Bild 3 von 3
    • Remove the screws marked.
    • The Screw on the left is located underneath the cable.
    • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 18-21, Garner Spring 2011 Mitglied von Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 6,311
