Einleitung
The Nokia Lumia 1020 phone battery is internally located. The battery is removable and replaceable, but accessing it requires the user to open the device by removing the screen.
  1. Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
    • Unscrew the two 4 mm torx screws on the top silver strip with a T4 screwdriver.
    • Unscrew the 4.5 mm torx screw above the gold bar with a T6 screwdriver.
    • Grab the edges of the gold strip with gripped tweezers to remove. The gold and silver metal will come off together.
    • Be careful not to puncture the battery. Use a spudger to slice the black tape on the left side of the battery.
    • Remove the battery with your finger.
    • Wedge a spudger underneath the small black rectangle attached to the battery until it pops off.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sydney Hostelley
Mitglied seit 15.02.2018
510 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G4, Leahy Spring 2018 Mitglied von USF Tampa, Team S1-G4, Leahy Spring 2018
USFT-LEAHY-S18S1G4
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 40
Letzte 30 Tage: 131
Insgesamt: 919
