Einleitung
The Nokia Lumia 2520 is a tablet manufactured in 2013 and has a Microsoft based software. The tablet display has a 10 inch display size while producing a resolution of 1920x1080 pixels. If the screen on the Lumia 2520 is clean and not broken and the display on the tablet is pixelated or faded; the display assembly inside the tablet needs to be replaced.
This guide will demonstrate the steps needed to safely remove the display assembly for replacement.
Was du brauchst
Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
Pull the ribbon cable out from the connection port on the board.
Move on the step 4 to remove the ribbon connection from the screen.
