Zum Hauptinhalt wechseln
Nokia Lumia 520 Audio Jack Replacement
Was du brauchst
  1. Nokia Lumia 520 Audio Jack Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia Lumia 520 Audio Jack Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Audio Jack Replacement: Schritt 2, Bild 1 von 2 Nokia Lumia 520 Audio Jack Replacement: Schritt 2, Bild 2 von 2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Audio Jack Replacement: Schritt 3, Bild 1 von 2 Nokia Lumia 520 Audio Jack Replacement: Schritt 3, Bild 2 von 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
  4. Nokia Lumia 520 Audio Jack Replacement, Audio Jack: Schritt 4, Bild 1 von 3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: Schritt 4, Bild 2 von 3 Nokia Lumia 520 Audio Jack Replacement, Audio Jack: Schritt 4, Bild 3 von 3
    • Unscrew the 8 screws with a Torx screw driver (T4) and make sure you know what screws went where because they are different.
  5. Nokia Lumia 520 Audio Jack Replacement: Schritt 5, Bild 1 von 2 Nokia Lumia 520 Audio Jack Replacement: Schritt 5, Bild 2 von 2
    • Use your plastic spudger to remove the clips on the plastic casing over the motherboard. Note there are 10 clips holding the casing on(3 on the sides, 2 on the top and bottom).
  6. Nokia Lumia 520 Audio Jack Replacement: Schritt 6, Bild 1 von 2 Nokia Lumia 520 Audio Jack Replacement: Schritt 6, Bild 2 von 2
    • Carefully unclip the digitizer touch screen cable and the display screen cable using the spudger.
  7. Nokia Lumia 520 Audio Jack Replacement: Schritt 7, Bild 1 von 2 Nokia Lumia 520 Audio Jack Replacement: Schritt 7, Bild 2 von 2
    • Gently remove the motherboard.
  8. Nokia Lumia 520 Audio Jack Replacement: Schritt 8, Bild 1 von 2 Nokia Lumia 520 Audio Jack Replacement: Schritt 8, Bild 2 von 2
    • Use the plastic spudger and gently remove the audio jack and the flex connector to the audio jack away from the case.
    • You will feel some pressure since the audio jack is held in place with two sided tape.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Mitglied von UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 2,655
