Zum Hauptinhalt wechseln
Nokia Lumia 520 Battery Replacement
Was du brauchst
  1. Nokia Lumia 520 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia Lumia 520 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Battery Replacement: Schritt 2, Bild 1 von 2 Nokia Lumia 520 Battery Replacement: Schritt 2, Bild 2 von 2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Battery Replacement: Schritt 3, Bild 1 von 2 Nokia Lumia 520 Battery Replacement: Schritt 3, Bild 2 von 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Mitglied von UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
3 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - Antwort
Greetings I have a Lumia & I need the Screen and Battery,so how can I get those 2?
Ayoba - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 41
Insgesamt: 3,669
