Einleitung
Follow this guide to repair the glass and frame.
With a thin tool, unhook the central body from the back cover, along the entire profile of the phone
Unclip the touchscreen connector
Unhook the display connector
Unhook the motherboard from the central phone body
Pull up the central frame from the touchscreen assembly by lifting the clips on the perimeter with a thin tool.
Remove the light sensor from the old frame with the help of a heat source.
Insert the sensor in the new frame.
Remove film that protects double-sided adhesive from the new touchscreen glass
Insert flat touchscreen into the frame slot and adhere the double sided adhesive to the frame by placing it in the correct position
To reassemble the device, follow these instructions in reverse order.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
