Zum Hauptinhalt wechseln
Nokia Lumia 521 SIM Card Replacement
Was du brauchst
  1. Nokia Lumia 521 SIM Card Replacement, Battery: Schritt 1, Bild 1 von 2 Nokia Lumia 521 SIM Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 SIM Card Replacement: Schritt 2, Bild 1 von 1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 SIM Card Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
Abschluss
Marko Stanisic
322 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 2-4, Sullivan Spring 2016 Mitglied von USF Tampa, Team 2-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,538
