Was du brauchst
Check condition of switches on logicboard
Rule out failure of cover
Remove cover, battery and SIM
Remove 6 torx screws
Note: Green is fine thread
Note: Red is coarse thread
There is a clip that needs to be moved out of the way before the board will move.
Start by lifting long side of logicboard
Gently wiggle and lift
Undo plastic clips near battery with force
Put back logicboard
Make sure pins near camera line-up
Note: Plastic clips need quite some force
Gently tighten screws
Put back SIM card and battery
Close cover
Enjoy the result ;)
11 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
hafıza kart okuyucu çalışmıyor ne yapmam lazım
Omg it looks complicated
