Zum Hauptinhalt wechseln
Nokia Lumia 635 Display Assembly Replacement
Was du brauchst
Einführungsvideo
  1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: Schritt 1, Bild 1 von 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: Schritt 1, Bild 2 von 3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: Schritt 1, Bild 3 von 3
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory cards.
    • Remove the black tape near to the loudspeaker.
  2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: Schritt 2, Bild 1 von 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: Schritt 2, Bild 2 von 3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: Schritt 2, Bild 3 von 3
    • Remove the 9x Torx T4 screws.
    • Two of them are with the same head size but with a different length.
  3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: Schritt 3, Bild 1 von 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: Schritt 3, Bild 2 von 3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to remove the back cover.
    • Careful unhook the display assembly flex cable.
  4. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: Schritt 4, Bild 1 von 3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: Schritt 4, Bild 2 von 3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: Schritt 4, Bild 3 von 3
    • Insert wisdom here.
  5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: Schritt 5, Bild 1 von 2 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: Schritt 5, Bild 2 von 2
    • Put some scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
  6. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: Schritt 6, Bild 1 von 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: Schritt 6, Bild 2 von 3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: Schritt 6, Bild 3 von 3
    • Start the separating from the upper right corner, where you have an hole in the middle frame.
    • Use plastic tool to prevent the middle frame from scratches.
    • Work slowly, you can cut your fingers.
  7. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: Schritt 7, Bild 1 von 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: Schritt 7, Bild 2 von 3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: Schritt 7, Bild 3 von 3
    • Clean the middle farme.
    • Put adhesive tape 3MM.
    • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
    • It's easier if you order the spare part together with an adhesive tape.
    • Install the display assembly.
  8. Nokia Lumia 635 Display Assembly Replacement: Schritt 8, Bild 1 von 2 Nokia Lumia 635 Display Assembly Replacement: Schritt 8, Bild 2 von 2
    • That's all.
    • Did you do it successfully?
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.278 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.528 Anleitungen geschrieben
2 Kommentare
Exactly what I needed! Step by step detailed instructions along with what tools I would need. Heating it up took longer than expected & it took me longer than 30 min, but I actually set aside 2 hours to replace my screen. Woohoo I finally I have a new screen & I did it all on my own...well with the amazing help from ZFix ;D
beatriz_ibre - Antwort
how to fix the display
Roneil Mcintosh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 9,815
