Einleitung
Nokia Lumia 720 - How to replace Coaxial Antenna Cable.
Was du brauchst
Einführungsvideo
Remove the SIM card tray and the memory card try.
Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
Use plastic tools and start the separating the back cover from the top side.
Remove the 3x Torx T4 screws.
Buzzer / Loudspeacker
Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
Fast fertig!
Abschluss
