Einleitung
Nokia Lumia 720 Display Assembly Replacement - Touch Screen Glass and LCD Display.
Was du brauchst
Einführungsvideo
Remove the SIM card tray and the memory card try.
Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
Use plastic tools and start the separating the back cover from the top side.
Remove the 3x Torx T4 screws.
Buzzer / Loudspeacker
Disconnect the battery flex cable.
Unstick the metal foil from the logic board.
Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
Disconnect the Volume, Power and camera buttons flex cable.
Remove the 4x Torx T4 screws.
Slightly lift the board
Disconnect the Display Assembly flex cable.
Disconnect the Charging Dock Board flex cable.
Remove the Main board.
Use a hair dryer and warm the flex cable.
Careful unstuck the flex cable from the middle frame.
Micro USB connector
Microphone
Warm the flex cable and detach it.
Now you can start with the reassembling, but before you place the back cover, test the new display assembly.
5 weitere Personen haben diese Anleitung absolviert.
