Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing. Using the opening tool, pry the screen from the casing until they are separated from each other.
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Detach camera ribbon from motherboard
    • Detach camera ribbon from motherboard
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Peel camera off of adhesive surface
    • Peel camera off of adhesive surface
    • Use caution when removing camera as it is fragile
  5. Apply adhesive to back of camera
    • Apply adhesive to back of camera
    • Attach ribbon to motherboard
    • Press down on camera for 60 seconds
    • Let dry for 5 minutes
  6. Slide the hinges of the left side of the screen under the left side of the plastic case
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Joshua Crosman
283 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G1
3 Mitglieder
Is also forgot to tell about the plate between screen and battery that is glued to the battery
John Bork - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 538
