Was du brauchst
Schritt 1 Opening The Phone
Achtung: Schritt 1 stammt von einer Anleitung, die derzeit bearbeitet wird.
Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
Using the opening tool, pry the screen from the casing until they are separated from each other.
Apply adhesive to back of camera
Attach ribbon to motherboard
Press down on camera for 60 seconds
Let dry for 5 minutes
Slide the hinges of the left side of the screen under the left side of the plastic case
Clamp the right side of the screen down and make sure screen is flat
The screen should "click" into place
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
