Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing. Using the opening tool, pry the screen from the casing until they are separated from each other.
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Detach connector from the phone.
    • Detach connector from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Detach Connectors that are attached from the screen to the motherboard.
    • Detach Connectors that are attached from the screen to the motherboard.
    • Screen can now be removed with little effort.
  5. Using a pair of tweezers, remove rubber gaskets that are holding the motherboard in place.
    • Using a pair of tweezers, remove rubber gaskets that are holding the motherboard in place.
  6. Starting in the bottom left corner of the device, insert a wedge between the motherboard and the case.
    • Starting in the bottom left corner of the device, insert a wedge between the motherboard and the case.
    • Gently pull up with the wedge allowing for the motherboard to gently click out of place.
    • Gradually repeat this process around the entire motherboard until it becomes easy enough to remove completley from the casing.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Joshua Crosman
296 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G1
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,579
