Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing. Using the opening tool, pry the screen from the casing until they are separated from each other.
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Detach both ribbon connectors from the logic board.
    • Detach both ribbon connectors from the logic board.
    • Attach new screen connectors to logic board
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Joshua Crosman
296 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G1
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,797
