Zum Hauptinhalt wechseln
Nokia Lumia 920 Volume, camera, and power ribbon. Replacement
Was du brauchst
  1. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Remove the Bottom Screws: Schritt 1, Bild 1 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Remove the Bottom Screws: Schritt 1, Bild 2 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Remove the Bottom Screws: Schritt 1, Bild 3 von 3
    • Make sure the phone is off.
    • Use the T5 screwdriver to remove the two 8.6mm long screws, located at the bottom of the phone. (Head size is 2.5mm)
  2. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 2, Bild 1 von 2 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 2, Bild 2 von 2
    • Use the smallest Torx screwdriver or another small poking tool and push into the hole on the SIM card slot. The plastic SIM protective piece should pop out quite easily.
    • Put that plastic piece aside.
  3. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 3, Bild 1 von 2 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 3, Bild 2 von 2
    • Once both screws on the bottom are removed, and the plastic SIM protective piece is removed, gently push on the outside of the screen.
    • The screen should become separated using little force. And should like the pictures shown once complete.
  4. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 4, Bild 1 von 2 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 4, Bild 2 von 2
    • This step may be easier to remove the battery first, but it is not mandatory.
    • Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
    • Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
  5. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 5, Bild 1 von 2 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 5, Bild 2 von 2
    • Once the metal clip is removed, gently pry up on the ribbon cable connection, located underneath the metal clip you have just removed.
  6. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Battery: Schritt 6, Bild 1 von 2 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Battery: Schritt 6, Bild 2 von 2
    • Prerequisite step: Back panel removal
    • Use the T4 torx screwdriver to remove the 3mm screw (diameter of the head is 1.5mm) fastened to the metal clip, holding the battery in place.
  7. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 7, Bild 1 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 7, Bild 2 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 7, Bild 3 von 3
    • Using the plastic opening tool, pry up on the metal clip holding the battery in place.
    • Completely remove the clip.
  8. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 8, Bild 1 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 8, Bild 2 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 8, Bild 3 von 3
    • Use a plastic opening tool. Start on the right, and gently lift up on the copper strip.
    • You do not have to completely remove the copper strip, only enough so that the connection to the battery is visible.
  9. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 9, Bild 1 von 1
    • Use a plastic opening tool or spudger, and gently lift up on the connective piece.
  10. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 10, Bild 1 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 10, Bild 2 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 10, Bild 3 von 3
    • Use a plastic opening tool at the bottom of the battery and gently lift.
    • The battery should lift out easily.
  11. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Volume, camera, and power ribbon.: Schritt 11, Bild 1 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Volume, camera, and power ribbon.: Schritt 11, Bild 2 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement, Volume, camera, and power ribbon.: Schritt 11, Bild 3 von 3
    • Prerequisite guides: Back panel removal, Battery Removal
    • Use the plastic opening tool to gently lift up on the connective piece attached to the volume, camera, and power button strip.
  12. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 12, Bild 1 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 12, Bild 2 von 3 Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 12, Bild 3 von 3
    • Flip the front panel on its side with the strip you are working on facing upward.
    • Use a spudger tool and starting at the top, gently pry the button sensors up.
    • Slide the tool underneath the strip and pry up the next button sensor.
    • Do this down the line until the strip becomes completely detached.
  13. Nokia Lumia 920 Volume, camera, and power ribbon. Replacement: Schritt 13, Bild 1 von 1
    • The power strip should look like this fully detached.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Jonathan
1.513 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 4-2, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-2, Miles Fall 2014
UMASSD-MILES-F14S4G2
2 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 18
Insgesamt: 5,713
