Zum Hauptinhalt wechseln
Nokia Lumia 925 Speaker Replacement
Was du brauchst
  1. Nokia Lumia 925 Speaker Replacement, Motherboard: Schritt 1, Bild 1 von 2 Nokia Lumia 925 Speaker Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Speaker Replacement: Schritt 2, Bild 1 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 2, Bild 2 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Speaker Replacement: Schritt 3, Bild 1 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 3, Bild 2 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Speaker Replacement: Schritt 4, Bild 1 von 2 Nokia Lumia 925 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Speaker Replacement: Schritt 5, Bild 1 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 5, Bild 2 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Speaker Replacement: Schritt 6, Bild 1 von 2 Nokia Lumia 925 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
  7. Nokia Lumia 925 Speaker Replacement, Display: Schritt 7, Bild 1 von 2 Nokia Lumia 925 Speaker Replacement, Display: Schritt 7, Bild 2 von 2
    • Push the screen from the inside of the phone.
    • Pull the screen off.
    • Slide the electronic strip through the small opening.
  8. Nokia Lumia 925 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 1
    • Locate the grey speaker/camera cover.
    • Carefully remove the cover with either a pair of tweezers or your fingers.
  9. Nokia Lumia 925 Speaker Replacement: Schritt 9, Bild 1 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 9, Bild 2 von 3 Nokia Lumia 925 Speaker Replacement: Schritt 9, Bild 3 von 3
    • With a pair of tweezers, gently remove the orange colored tab closest to the speaker.
Abschluss
Guillermo Lara
409 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 207
