Zum Hauptinhalt wechseln
Nokia Lumia 928 Rear Facing Camera Replacement
Was du brauchst
  1. Nokia Lumia 928 Rear Facing Camera Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nokia Lumia 928 Rear Facing Camera Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Power down the phone.
    • There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
    • The screw does not come out. Once loosened, It will unlock the lock bar inside the phone. You will break it if you do not complete this step properly.
    • Remove the sim card tray on the top of the phone.
    • Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
    • There is a sticker located on the screw that needs to be peeled off. This voids your warranty.
  2. Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 2, Bild 1 von 3 Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 2, Bild 2 von 3 Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 2, Bild 3 von 3
    • Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
    • It can be useful to flip the plastic opening tool upside down in certain areas of the phone to make releasing the plastic clips easier.
    • Once all the clips are released, remove the back cover of the phone.
  3. Nokia Lumia 928 Rear Facing Camera Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Remove all 10 T5 screws on the motherboard. All screws are 4.5 mm Torx T5 screws.
  4. Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 4, Bild 1 von 2 Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 4, Bild 2 von 2
    • Remove the ribbon connector with a highlighted with a red circle with the plastic opening tool.
    • Be very careful with the ribbon connectors as they can easily be ripped off.
    • The ribbon connector highlighted in yellow has a zero insertion force connector. This has a black flap on the end that needs to be flipped up before the ribbon cable can be pulled out.
  5. Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove USB port cover using the plastic opening tool, or your hand. It can be removed easily.
  6. Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 6, Bild 1 von 2 Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 6, Bild 2 von 2
    • Pull up the left side of the motherboard.
    • There is 1 connector that needs to be removed with the plastic opening tool highlighted with a red rectangle. Do not pull the motherboard away from the display assembly until you have removed it.
    • You have now removed the motherboard from the display assembly and the back cover.
  7. Nokia Lumia 928 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 7, Bild 1 von 1
    • Lift up the connector for the rear facing camera using the plastic opening tool.
  8. Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 8, Bild 1 von 2 Nokia Lumia 928 Rear Facing Camera Replacement: Schritt 8, Bild 2 von 2
    • Push the camera out from the side that has the camera housing sticking out (the side in the picture) using the rear end of the plastic opening tool, or your pinkie finger.
    • You have now removed the rear facing camera.
Abschluss
Curtis Dawe
461 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 6-8, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 6-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G8
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 196
